I have some thin sheet metal items, eg 2mm material, & when I try to “push” circular holes they only go part way through.
I have found that if I make the item a component with attributes I can then make it thicker, ie 20mm & I can then cut a hole through, then reduce the material back to 2mm which is then ok.
Seems a nit messy, Is there any other way around this ?
This morning I re did the job & it is cutting thro 2mm fine so I don’t know what the problem was. Thanks for the tip I will try that if it happens again.
Bob
