Printing surface not visible in SketchUp model
My print is printing a solid layer starting at the top of the array of cross rungs, but is not visible in either SketchUp or in the slicer (Cura). I have hidden geometry enabled and don’t see anything that should result in this.
Note I am using SketchUp Free, and this was based on a similar part and I simply deleted every other rung and added the detent bumps on the end inner walls. I also enabled Hidden Objects and the model appears to have no surface.
What tools and next steps can I use to diagnose this issue?
Image and SKP file included:
Dehydrator Top v2.skp (121.8 KB)
Those gray faces are back sides… you should start by reversing them (everything should be white).
Thank you Aaron! That seems to have resolved it, and I don’t know how I reversed them as they are correct in the original part model, but I’ll be watching for that going forward.This will be my next topic to learn and understand as a user new to CAD. And the file and estimated time are now in line with the print volume.
