Whwre can I find the “position bar”?
I’m not sure what that means for you …
https://help.sketchup.com/en/sketchup/getting-started-sketchup#explore-interface
https://help.sketchup.com/en/sketchup/customizing-your-workspace
If you mean the dimension box, it may be hidden by your taskbar. Try maximizing the SketchUp window, or make the height of the window be less tall, then move the shorter window upwards.
I’m serching the toolbar location. There isn’t. If I go to View toolbar Ithere isn’t
Excuse me, I mean the toolbar “Location” there isn’t . If I go to View Toolbar there isn’t
I guess you have been used 2 or more monitors before.
a). Connect your second monitor back and locate the Toolbar window there
b.) If that is not possible, follow this guide exactly after opening the toolbar as usual (Menu>>View>>Toolbars…)
- Hold down the ALT key. Hit SPACEBAR.
- Release ALT key
- Hit M (Move).
- Hit one of ← ↑ → ↓ arrow keys
- Move your mouse around (without pressing any mouse key) until you see the missing window.
- Press left mouse button on the desired place
( Note I assume you have English windows otherwise you may need to replace “M” with a localized start letter)
