PlusSpec: Can't change the door open direction
*There should be a swing under the door but I don’t know why it’s disappeared. Now I can’t change the open direction of the door :cry:. Anybody know why?
Most likely z-fighting with the floor, and the floor won.
You could try temporarily hiding the floor surface.
I have the same issue. did you manage to fix it?
First hide the floor if any to ensure its not being hidden, else check the layer/tag is visible . From memory the swing is on tag ‘Floor Plan A’.
