All of mind.sight.studios extensions are updated for SU2027 except for DECAsteel. You just need to download the latest versions from our product websites. Easiest path is to login to our My Licenses portal and get all of them there.
Since SketchUp is so barebones without Extensions, and we need them to actually get real efficient work done in SketchUp, this process should be completely automated with full visible log of any problems. Install a new SketchUp? It does try to import your existing plugins now, but not update them. It should automatically do that. Users should only have to install once and be done. Updates and compatibility are handled automatically with clear logs and easy to see and fix for those that need it.
Right now, it’s a major pain to go and find the updated version for all the plugins when they get broken since many of the useful ones do not auto update.
Since most extensions come from either the Extension Warehouse or Sketchucation, it should be simple enough to update them. With Sketchucation in particular all you need to do is install the Sketchucation Extension Store and let it install your bundle with the latest updated versions of the extension.
Some of the best extensions are from independent sources like those from Curic do not auto update and need to be updated individually. If only Trimble would consolidate this process into a single extension install and update process.
I don’t think the request is possible because of web page address changes over time for the various hosting sites.
So you need to get on authors like Curic to make their updates available through the Extension Warehouse or Sketchucation so that updates are easier to manage. If those authors prefer to remain separate from the Extension Warehouse or Sketchucation it’s on them to make it easier to update their extensions. Especially so when they charge the users for them.
Trimble has provided a very usable avenue for hosting extensions. If authors choose not to use them it should not be on Trimble to deal with updates.
I don’t need to do anything there @DaveR !
For maximum compatibility and ease for users, Trimble should be forcing extensions to run through a transparent and openly approved extension manager and warehouse with a single install and update process.
Right now they can deny extensions for whatever reason without explanation. This forces developers into other warehouses and independent run extension installs. Open it up with a transparent approval process and everyone wins.
Without it, the segmentation of all this brings down the SketchUp experience.
I must disagreed with you. Many authors - including myself and Fredo6 - have long ‘fallen out’ with the EWH and they prefer the less onerous and more friendly SketchUcation ExtensionStore [which predates the EWH] and SCF-Licensing system. We realize that at any time Trimble could introduce draconian powers to force all authors to use their restrictive extension system and the EWH. This is unlikely as the backlash would be users not updating to a newer SketchUp version to keep their ‘now-noncompliant’ extensions running. But I think we’ve all had enough of ‘fascist dictatorships’ - both on the right and on the left. So in conclusion I cannot agree with your position in the slightest. If you put ideas into Trimble’s head they might [disastrously] go down the Revit path - I used to also write customized toolsets for Revit, but then AutoCAD introduced a system for ‘approved Revit authors’ which sounded good from a user’s view point, but meant that I would have to pay a fee of ~$1000 a year simply to be ‘approved’ - even if I earned no money that year ! Combined with their annual changes to their API [which were far less kind than the current Ruby API] meant that every new Revit version needed a full rewrite of my tools - as they did not ‘deprecate’ methods to allow authors time to make adjustments, but completely either replaced or renamed them - or changed their functionality… None of this is recommended from anyone’s viewpoint except for the controlling company…
Awesome post and information! Thank you for you valuable insights here.
My hope is that we can simplify the advanced users experience. Updating is only one part of this and while I have not bothered with the SketchUcation Extension store in a long time due to the terrible website, I understand it may make updating a lot easier and is better for independent devs. Do you have any pull to suggest they redesign their archaic and difficult to navigate website?
I dream of having a unified look and feel to SketchUp with powerful native tools so that you don’t need many extensions. Until then we must use extensions to get real work done efficiently and some of them are really ugly and non intuitive to use at all. For example, FredoTools, I’m sorry, your tools are cool but the UI is intolerable. They are like looking at a 90s DOS app. The same goes for many other great tool ideas I have seen. If these would follow the SketchUp UI style rules and be made much more intuitive to use with better documentation on how to use them, I would be more on board.
As it stands, I will still keep dreaming of a more unified SketchUp with powerful native tools included. I truly believe most of these tools already exist and Trimble should just buy the IP to take them over from the developers. They certainly have the money to do that. If SketchUp continues down the boring path without better native tools, I believe one of these other more robust or more open apps like Rhino will take over a huge share of previous SketchUp users.
I’m not asking that to happen here. I’m suggesting SketchUp widen the narrow path that has angered so many users in the past, moving toward a bigger and brighter future.
The SketchUcation website and dialog appearance was overhauled a while ago - so it might now be more to your taste ?
I must agree with you about Fredo’s interfaces, but he is a power unto himself ! You could try starting a dialog with him over at SketchUcation…
However, before we authors rush out and ‘fix’ our interfaces - Trimble itself has a lot to answer for with its newer SketchUp appearance, which has also attracted a lot of criticism as being ‘insipid’ and not always as clear as the older version…
Which is interesting as MindSight just moved all of their tools off of EWH.
back in… 24 ? (previous ruby update) it took Anton a couple of month to update Clothworks I think.
there is still hope.
yeah, the influx of vibecoded ai plugins (many of them providing an already existing free service… for a small fee) since spring has caused a nice bottleneck in the update system, making several plugin developers just stop using the EWH.
Turns out, when you don’t make many updates to your plugins, you can rely on a simple website + emails / newsletters like Curic (and minsight now) is doing. but they are well established names in the game. not so simple for a newcomer. then again, not so simple to make your mark in the current EWH either.
