[Plugin] ElevationProfile - Vertical Analysis of curvilinear profiles
Thank you for the update. The problem persists. And I found which button causes the Issue:
It would not export only if in the table orientation “column by sampling” is on. If “column by property” is on, then it works fine. You may check that. Thanks
Another bug, fixed in ElevationProfile v1.2b, just published
Works as intended now. Thanks
Amazing job :D.
Hi Fredo. I have purchased tools and use them very often - very useful and powerful. Yesterday I came across one issue - I subdivided a curve using a Polyline Segmentor and then tried to weld the segments using the Curvizard. The result is always very awkward - it creates a completely different curve, out of place while the segments remain in position and not welded. Could you please investigate why this happens and fix it as soon as you can as I need to do this regularly.
