medeek
1
I thought the API has a built in detection for rounding off floats, or some sort of tolerance, correct me if I’m wrong.
I’m trying to take a collection of faces and eliminate the vertical faces:
@roof_faces = @all_roof_faces.find_all {|f| f.normal.z != 0.0 }
This sort of works but the results are unpredictable.
medeek
2
This seems to work:
@roof_faces = @all_roof_faces.find_all {|f| f.normal.z.round(3) != 0.0 }
Try …
@roof_faces = @all_roof_faces.reject {|f| f.normal.perpendicular?(Z_AXIS) }
You’re wrong. It’s Core Ruby that has this functionality.
medeek
4
That is the cleaner way to handle the task.
tt_su
5
The Length
class compares with the tolerance SketchUp use for length units. But if you have a Float
you need to perform this yourself.
In the example you provide you are dealing with geometric coordiantes so it’d be appropriate to ensure you use Length
s:
@roof_faces = @all_roof_faces.find_all {|f| f.normal.z.to_l != 0.to_l }
