Perspective zoom trouble
#1
I’m not sure what I did to cause this, but whenever I zoom in on something, it starts to disappear as if its not there. I believe what is happening is supposed to be normal, but not at this level.
tWhat I will have is everything will look normal, until I zoom in and get this:
The gap between those stairs is 6 feet, whereas before this type of problem wouldn’t occur until i was looking at something an 1/8th of an inch wide. Any help you can offer to fix this would be great.
#2
It’s ‘Clipping’, you can search up the several responses and suggestions to avoid this in this forum or Google.
#3
None of the methods on this page (http://help.sketchup.com/en/article/36261) worked. Model is not too big or small, nor too far from the origin, nor have any parts far away, and the field of view is still 35 degrees.
#4
can you post the model?
john
#5
Have you used the advanced camera tools? They are known to cause this depending on their placement and settings.
#6
Yes, I have. Is there a way to undo that?
#7
How do I do that? I’m rather new to sketchup.
#8
See the section in this tutorial about deleting ACT cameras:
