Parallel view shown cut
How do I do to have the entire rear view shown without moving the building? Now it shows cut.
I understand that this happens with some parallel views but I don’t know how to fix this situation.
I am attaching the file.
Thank you.
Survey.skp (238.6 KB)
As a quick fix you can rotate the model until the back wall is visible, then open the group containing the rear wall. Right click on the wall and select align view. Then reposition the camera and update the scene.
The problem with Parallel projection is it can’t cope with zooming correctly. So it has effectively shoved the camera inside the building.
Go to perspective and get it out then reset your scene.
Clip
Thanks a lot Box, that is exactly what I wanted to learn!!!
Thank you Shep!!!
It works well this way.
