Rendering the language is defined as a view …
but on the type of 3D rendering software is a process of formation of a dot matrix file into a bitmap file …
on googke SketchUp if the current rendering process often fails BUGSPLAT it means TEMP files already crossed the line, the solution is to open Windows Explorer> user and find the name of your computer or my computer (my computer to use the name wandi2000) previously used a computer hidden in the open so that the entire file is hidden can be seen> appdata> local> select tempfile> dellete all temporary files that can be deleted, if anyone who can not finish in SKIP wrote … well now you can with a normal renders without having to interfere BUGSPLAT …
may be useful…
I like to use the free utility CCleaner to clean out assorted temp files as a part or routine computer maintenance. Would using a general cleaning utility like this also clear the rendering temp files - with a few less clicks? .
