After thinking about doing it for several years I’ve finally gotten around to clean up the old and dirty code in my solid tools to a state where I can open source it. This project was actually started not with the intention to be a standalone plugin, but because I needed sensible solid operators for another plugin. I have used it in several plugins since and thought more people might find it useful.
There are several differences from the native solid tools. My version modifies the existing group/component instead of creating a new one. It also honors the existing materials on both group/containers and on individual faces instead of painting individual faces with the container’s material. Both these properties makes it really useful in custom plugins because it behaves much more consistently to SketchUp than the native solid tools.
I’m really happy with the UX; several people have commented in the Extension Warehouse and said it’s easier to use that the native solid tools. However I’m not really an algorithm person so it would be really fun if someone here wanted to optimize and improve stability.
I don’t know if this RubyDoc.info supports TomDoc. However I’m prioritizing having clearly readable comments in the actual source while working on it than on some third party website. For now the documentation can be read in the source code directly.
YARD should display TomDoc comments quite well. Give it a try. (It’s only a switch in the GitHub repo settings. You can always switch it back off.)
YARD is not so different and quite readable. (What I was doing was trying to get you to perhaps understand that the majority of open source Ruby projects are using YARD. I would be surprised if TomDoc had more than a few percent of the total share.)
As you may have noticed I’m new to using rybydoc.info. Now the docs are generated from the source files but the parser fails on some occasions. It treats comments not related to any specific methods as the method documentation and treats argument descriptions as code. Adding “–plugin tomdoc” to the .yardopts file doesn’t seem o make any difference whatsoever.
Version 3.0.0 was released yesterday. Subtracting and trimming multiple solids at once is now possible. There are also some bug fixes related to volumes with interior holes in faces and coplanar faces being wrongly merged.
And by the way, yard is now used for documentations!
