# Open .dxf in SUPro via Inkscape
**URL:** <https://forums.sketchup.com/t/open-dxf-in-supro-via-inkscape/189314>\
**Category:** Pro\
**Created:** [February 8, 2022, 10:40pm UTC](https://forums.sketchup.com/t/open-dxf-in-supro-via-inkscape/189314 "2022-02-08T22:40:56Z")\
**Showing post:** 4
**Author:** ![paul.millet](https://sea2.discourse-cdn.com/sketchup/user_avatar/forums.sketchup.com/paul.millet/32/236258_2.png) [@paul.millet](https://forums.sketchup.com/u/paul.millet)\
**Post date:** [February 9, 2022, 5:46pm UTC](https://forums.sketchup.com/t/open-dxf-in-supro-via-inkscape/189314/4 "2022-02-09T17:46:56Z")
See this recent thread for texts :
> [@DWG files in Sketchup](https://forums.sketchup.com/t/dwg-files-in-sketchup/188916/5):
> hello, inside inkscape, select your text (or select one text then right click and select same \> object type, to automatically select every text objects) then go to path menu and pick object to path. -note that you might have to double click several time to enter the groups that contain the texts before being able to select them - It will convert every editable text into vectors that you will be then able to import inside sketchup This method is similar to illustrator’s decompose function
_[View the full topic](https://forums.sketchup.com/t/open-dxf-in-supro-via-inkscape/189314)._
