is there a way to open AutoCad using ruby is a specific file
From within SketchUp ?
UI::openURL("path/to/some.dwg")
You might also use try a %x
execute string.
%x{acad.exe "path/to/some.dwg"}
And then there is a Wscript command using the Win32OLE
class.
Something like this (untested.) Correct the paths if need be.
(Also if the user has changed the AutoCAD directory name or install disk the normal paths will not work.)
module Author
module SomePlugin
require 'win32ole'
ACAD = File.join( ENV['PROGRAMFILES'], 'AutoCad', 'acad.exe' )
def open_in_acad(pathname)
shell = WIN32OLE.new("WScript.Shell")
shell.Run( "#{ACAD} #{pathname}", 1, false)
end
end
end
