Hello
I need the hel from the helds of the sketchUp
I would like to 3d print a label (with my name) for my door
I have create a flat surface with relief text (to priunt in black)
And a cover with the negative empty text ( to print in white)
But i need to have a gap between the positive and negative text ( to compensate the printer resolution)
I have try to scale the text but if I do this it change the position (also with ctrl press)
Offset command do not work
How I can solve my problem?
Start with the text as 2D and make a copy of it. Make the copy unique and then use Offset on the edges. I used an offset distance of 0.1mm. Then make the extrusions as needed.
The model is ok on sketchup but when I slide it is wrong??? Cura create the hole for the letters but full fill the last layers
I need to investige about it on cura forum
