Off cuts in open cutlist
Hey,
I’m using Open cutlist extension. How do I include off cuts into the panels so I can use up odd pieces in the workshop? If I include them under sheet goods wont it think these are standard sizes and think there are more of these sizes then there really are?
TIA!
Pinging @boris.beaulant ..
Hello @makecarpentry ,
Panel off-cuts should be entered in the Off-cuts field of the cutting diagram configuration form :
Caution that in this case the cutting diagram algorithm will try to find the cheapest solution. So entered off cuts will be used only if it make sens to use them to find the cheapest solution.
That’s amazing thanks pal.
