I have a component that I would like to rotate off axis to the model. I re set the components axis using the rotation point to the x axis. The attribute behavior is animate(“rotx”,0,90)
When I interact with the component it first aligns itself to the model x then will rotate 0 to 90 along the component x.
Im sure I am missing something simple, any insight would be much appreciated.
if you check the other rotation values, you will see the rounded values of -8 for rotY, 4 for RotZ, if you rotate the lid manually, the new values are what you might not expect.
Rather than figuring this out, plus the values are rounded,
