Hello. I have created an entrance door object. The problem is that behind the front layer, the stripes of the object behind are visible. What could be the reason for this, how to fix the bug?
Search in forum and read about openGL and ‘bleed through’
Thanks a lot. I found the solution in your post. ![]()
In our parts, a door leaf is normally about 40 mm thick, unless it is a solid glass door.
