OAuth HTMLDialog redirect
I am here again ! Hello.
Why can’t redirect in htmldialog?
Hope to hear from you, very grateful.
I haven’t done any client-side js recently. I did run some code trying the above uri’s.
‘Redirect’ was a bad choice, as that often refers to a connection/host/http issue.
I think the problem may be when the OAuth code opens a second window from within an HtmlDialog.
In a normal browser, using OAuth from ‘AppVeyor, a second ‘modal’ style browser window is opened. When one does that with an HtmlDialog in SU, it opens a separate window in one’s default browser.
Trying the OAuth from ‘https://bintray.com’, within an HtmlDialog, it does appear to work, but I didn’t actually login.
I used those two sites because they both used GitHub OAuth… What problem are you having?
i just want to redirect in HTMLdialog.As you say, using OAuth from ‘AppVeyorin SU HTMLDialog,But it dose not work and no error in console.it make me trouble.
