The input field will not accept a zero when using the numeric keypad. All other numbers from numeric keypad will work in the input field. A zero will work using the normal numbers on the keyboard. The Zero will work from the numeric keypad when inputting dimensions into extensions. I have noticed that when I hit the zero key from the numeric keypad that the outliner from the default tray will “flicker” for a split second but nothing else happens. I have tried to see if the zero key is associated with a shortcut but have found none. The zero key from the numeric keypad works in all other programs and apps. Is anyone else having this issue?
I am using Sketchup 2018 Pro and I am using an Acer Aspire V17 Nitro running windows 10.
Yeah but the “0” key works in all other applications i.e; web browser, Word, Excel, including extensions within Sketchup that need numbers for say wall heights. It is a head-scratcher.
It doesn’t make any sense that a single key wouldn’t work.
Out of curiosity, when you installed SketchUp, did you right click on the installer file and choose Run as administrator. Other very weird things have been reported by users who didn’t install SketchUp with Run as administrator. Maybe it’s worth trying it now and selecting the Repair option.
