Not snapping on exact point
This window not snapping it’s desired point. Even it’s not moving inside direction. How to control Move Tool on exact direction? Any Tips…!
I expect the window component has gluing properties set which can prevent it from moving in the desired direction. Right click on it and select Unglue.
Share the .skp if that doesn’t work.
By the way, your profile says you are using SketchUp for Schools but your video capture doesn’t show that version. Which version are you really using?
I’m a novice. It’s Sketchup Pro 2021
Before moving, choose the point (for grip) you want to align
learn.sketchup.com
Please fix your forum profile. The wrong information there makes it harder for us to help you.
It’s working after Unglue
Good tips. Thank you
Good deal. And thanks for correcting your profile.
