Need help with woodworking plans
I’m making this odd pyramid shape for a woodworking project. I will be using 19mm MDF for the installation, but I am not able to figure out how to cut the bevels of the different pieces. How to go about this?
Picture:
Sketchup file:
Atmos.dae (22.9 KB)
Instead of sharing a .dae file, share the .skp file.
Here it is! :slight_smile:
Atmos rev.6.skp (192.6 KB)
Is this what you are hoping for?
Atmos rev.6.skp (51.2 KB)
I edited each object and gave it the 19mm thickness you want. Then using the neighboring objects I traced where they intersected to figure out the bevels and erase the waste. I did convert the groups to components and, since the two triangular ones on each side are symmetrical, I use Flip/Copy to copy the left hand ones to make the right side. The other thing I did is align the component axes so that if you run a cutlist for the model you’ll get useful dimensions.
Perfect! Thank you so much :slight_smile:
Downloaded an extension called “Angular Extension 2” and measured all the bevels. Now off to make some cuts… :slight_smile:
I’m glad that worked for you. What are you making?
@DaveR Sorry for late reply, wanted to get some photos. I’m building a home theater. Behind the drywall there are backer-boxes for loudspeakers. I wanted them angled towards the listener to avoid getting too far off-axis. Built 4 of the plans you made and attached them yesterday. Really appreciate the help :slight_smile:
(The brown stuff on the inside corners is just a mix of wood glue and saw dust that i applied to strengthen the structure. Don’t really think it was necessary though)
Cool! Nice work.Thanks for the pictures. It’s always good to see how SketchUp models get turned into reality.
