Need help on this mode, it was so heavy for a reson i do now know
hi, i am just wondering why this file is so heavy? i’ve tried to remove the possible cause of it but it is still laggy. Tried to purge it and use cleanup3 but still laggy. Here is the file, thanks!
Firstly all the plants are probably adding massively to the file. Then the timber screens is probably heavy too.
The rest we can only guess at from your screenshot.
i’ll try to remove the plants if it will get smoother. Thanks
yep, it was the plant. A really specific plant. Thank you so much :)))
Hello,
running quite fine here.
Make sure your RTX 3050 is the GPU being used (window > preferences > graphics > GPU selection) and not the Processor graphics
of course turn off shadows for better performances
Lay your plants on a separate tag that you can turn off while working on your model, optionnaly create scenes with/without to quickly toggle between states
thank you paul, i’d do that.
there is a free extension you can check, it’s called “CG impact report”
it checks your whole model, and tells you what groups or components contain the most elements, have the most copies, and represent the biggest total (elements x copies)
it’s very useful for cases like yours, you can identify quickly the “black holes” elements of your model.
thanks, ill check that out
