Need An Extension Developer
Hi All,
I’m sorry for my english…hopefuly I can explain clearly what I need.
I need a developer to develop an extension.
The extension will be “simple”.
  1. Generate Square/Circle/any form (Stars. Triangle etc), or user also can create the object first.
  2. Spread the generated Circle/Square onto a face/faces according to submitted sequence numbers (in csv or excel). probably using coordinate? the sequence numbers will be contain 0 and 1
  3. user has ability to select dimension of the square/circle (dimension), select the targeted face/faces, determine where the first point, the perimeter boundary, the distance between etc
Maybe some/another specifications will be explained more after I know the budget/rates.
Thank you
Hi!
Not sure what that extension suppose to do ;/
Could you give graphic example? How the end result should look like?
  1. ok
  2. how to spread the circle into face? By vertex? Not sure what 0,1 sequence should do
ps. you can also PM me
What I mean is like this
Let’s say I’d like to spread a circle onto a face (can be any form)…
You see, the circle is distributed onto the face. But its not random, the distribution follow a generated sequential numbers from left to right then below etc.
The sequential numbers supplied by CSV file contains only 0 and 1.
1 is where the circle is placed.
I also want the script also can define the distance between 0 and 1 (A-B) so there will be enough space, not overlap each other.
Or any extension out there capable to do this?
Thanks
Try a free extension named “Curic Face Array”, it may fit you.
china?
free 2024 version ?
