My SU setup needs a bunch of help. It’s been a few months. I am returning to SU after working on other projects for awhile.
To start with, the asset folders are empty: Components, Materials, Templates, Styles. All empty! Where those files went I have no idea. What should I do? Can I repair an installation?
No, they are not where they should be. If I go to the folders listed in Preferences for Components, Materials, Templates, Styles - those folders are empty.
Repair the installation and see what happens. Make sure you do it correctly. Right click on the downloaded installer and select Run as administrator. If theinstaller presents options select Repair. Make sure you have the lastest version of the installer.
SU is repaired as Admin. But the Materials, Components, etc folders in Preferences are still empty. Isnt there an assortment that comes automatically with every new install?
Those folders would contain materials, components, styles, and templates that YOU added so they wouldn’t be installed with the program. If those have been removed/deleted, they are likely gone. Are you sure they existed with SketchUp 2025? Maybe you have them in an earlier version of SketchUp, say in the same directory but SketchUp 2024?
Those folders don’t automatically get copied over when you install a new version of SketchUp. Part of my migration process when I install a new major release is to copy those folders from the previous version and paste them into the equivalent location for the new version.
