My SketchUp file says Fail to open. It was working last night only. Even the skb file is not opening. Help
Here is the link to file. https://drive.google.com/file/d/1rdIggSBlb68voXMpbGzRvYLSpeO5YJu6/view?usp=sharing
I could open your file on Sketchup 2026.2, I noticed there are a lot of stuff I presume were downloaded from the 3D WH, like the plants and other assets that unnecessarily increase the file size and make it lag specially if you´re using old hardware. Also all the exterior walls have inverted normals, that means that on monochrome style they should be white.
Just one tiny bolt that its not gonna be seen has over 15k entities, do you really need that level of detail?
Thank you.
I don’t need any of those files which is causing this issue. Please delete and and then modify into new file. Thank you so much, very much appreciated.
What version of sketchup are you using? You can download the latest one install it properly and open the file by yourself so you can delete all the stuff that you don´t need I could mess it up.
I am using 2025 Version. I am good with your deletion. Not an issue. If you have time you can sent me the updated one from your end. May be for the next project, I will download the new version.
Thank You.
I fixed some geometry like the right steel profile of the stairs so you can see how it should be done and reversed all the back blue faces i found, that might had messed with the textures, I didn´t check that I just worked on monochrome and fixing the textures would take a lot of time. I ran Cleanup 3 but didn´t delete the heavy groups and components.
Thank You Francisco. So much appreciated for your help.
Good Day.
