My rendering toolbars have dissapeared
My chaos cosmos license was not registering, so I signed in and downloaded the newest updates. I also updated my Sketchup Studio 26 license. I did a restart and my enscape and v-ray tools are showing in the extension, but I no longer have an asset manager or teapot shaped render tools. What am I missing? How do I get these back?
Do you have SketchUp 2026 installed? Your profile says you are using SketchUp 2022 on Windows 10. Is that correct?
Do you see the Vray toolbars in the list of available toolbars?
No, I am using Sketchup 2026 on Windows 11 now. The only V-ray toolbars are the V-ray material converter.
My available toolbars and loaded extensions are below.
Please update your forum profile with the correct information.
Did you install the current version of Vray for SketchUp after installing SketchUp 2026? Did you install both of them correctly by right clicking on the downloaded installers and selecting Run as administrator?
Yes, I am doing this for my third time now. I am curious though, V-ray installer prompts you for your version of Sketchup and it only lists 2024 and 2025. 2026 is not on the list. I wonder why this is and if there is a compatibility issue?
Looks like you don’t have the latest version of Vray for SketchUp. Or you didn’t install SketchUp correctly. When I run the installer it offers SketchUp 2026. Have you rebooted your computer after installing SketchUp 2026?
Yes I have re-booted many times as I have had Sketchup 2026 for awhile. I have restarted at least 3 times today. Maybe something in Sketchup 2026 did not install correctly. I will start with a fresh install of Sketchup. Thank you for your help. I really appreciate it.
Make sure you right click on the installer and select Run as administrator.
So, I uninstalled everything and re-installed. V-ray and render tools are now present, but it states that I do not have an active v-ray for sketchup license. However, it states that v-ray is included in our Studio version. Any thoughts on this? Did something change?
chaos is a well named company, and a few years ago they added the whole chaos licencing system that is truly a mess.
first, off course, restart your machine.
when prompted to login, be sure to login using Trimble. If you previously made an account using email and password, it probably won’t work.
I have a chaos account using my work email. and my trimble account is also under that email. But depending on how I login, I’ll get Vray, or I won’t.
so be sure to pick “continue with trimble”
this is using email + password
this is using trimble as login
same email though, but two results.
