I’m modeling a residential project where the basement level is a split level affair and has retaining walls around 3 sides. I need a section cut (plan view) to mark up in layout but the elements that I need to document are separated enough vertically that I can’t use single section cut to cut through all of the elements I need represented.
Is there a way to combine two section cuts (stacked) into one Layout viewport?
You could easily do this with stacked viewports or side by side viewports of two different scenes with different section cuts. I would put each viewpport on a different layer in LO so that you can lock one and leave the other available to work with if needed.
They can be if you turn off the background under the Style tab in the SketchUp Model utility window in LayOut. I think in this case you’ll have two viewports side by side, though.
I’ll take you up on that. I better be going. I’ll be working.
