Can somebody show me how to create an IF Statement with multiple else values in one attribute? I figured out how to make it work well when I have only two else values. =if(test,then value,else value)
I have 5 else values.
As far as I know, the dynamic components “language” implements if
not as syntax but as function:
if(test1, then1, if(test2, then2, if(test3, then3, else4)))
That worked perfect! Thanks so much.
When multiple if ‘s are involved, I tend to switch to CHOOSE() function
Hey Mike,
Im trying to get better with these formulas. It took like 2 weeks to figure out how to use the IF function well. Would you happen to have any model examples of how you use the CHOOSE Function?
Here is one:
If (you upload yours, If( I have time, I might check it, Others might))
Thank you for getting a lot on another item using these functions.
How do I download this to inspect it? thanks
Search for Dynamic-HEA
thanks
