Movement with Gravity Effects
I need help with creating a physical simulation in SketchUp. In my model (see attached image), I have several connected surfaces. When I select and lift the triangular section using the Move tool, I want the connected parts to also move naturally in response, as if they’re affected by gravity and physical properties. The connected parts should maintain their shape while responding to the movement of the selected area. Is there a plugin or technique that can simulate this kind of physics-based interaction in SketchUp?
You might be able to do that using clothworks
I draped this shape over a pedastal shaped collider using it rather than by lifting it.
You can interact wit it a bit whilst it is simulating
Before your reply, i was doing exactly same method :slight_smile: but yours more accurated version. thank you
