I noticed a bug in sketchup 2026 (desktop, in web it works fine), If I have an active section plane in a group in the model, I cannot press alt and cycle between the different grip types on groups that are located higher than that section plane, in previous versions this worked fine. Anyone else noticed this?
Did anyone else notice this problem @colin
It seems to work ok for me. Can you show a small model that is in the state where the grips don’t cycle? It’s possible I didn’t set up my test file exactly like yours.
move grips cycle.skp (32.2 KB) here is a file, if I try to cycle through the grip types on the small group (named ![]()
-I am having fun with emojis) it does not work.
Thanks, I see the problem happening in 2025 and 2026. If you uncheck View/Section Cuts, then you can cycle through the grips.
I logged a bug report about the problem, SKOR-21049 in our system.
thank you very much.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
