Move coplanar?
I waste too much time fighting with points and lines that should be coplanar … but are a little bit off. Yeah, sloppy modeling.
Is there an extension that will clean up my geometry, move it a bit, so it is nice and coplanar?
Joel
Vertex Tools and Eneroth Flatten to Plane come to mind. Also Projection Tools can work. Might make sense to work on not being sloppy in your modeling, though. As they say, β€œAn ounce of prevention is worth a pound of cure.”
Yes, Flatten to Plane does the trick! Thanks
Do you have length snapping on?
I’m not sure. How?
Also - do you lock your inferences and always type a value - unless connecting to another point or line or reference directly?
Yes and yes. Some stuff is together here!
You do have Length Snapping enabled? If so, that can contribute to some of your sloppiness.
Length snapping should be off / unchecked.
