It was very smart twinning Orbit and Pan into commands that could be switched between by merely holding down the shift key and the wheel to zoom in/out (forget the wheel click! It doesn’t work at all, even on a Microsoft HID-Compliant mouse). However, it would be even better if there were a way one could use the Alt and Alt/Control keys, or another keyboard key to call into play the Select tool (which seems to come into play just as much) and other tools one uses frequently.
- Is there a direct mouse/key path to the Select tool?
- Can you map keyboard key combinations to different SketchUp tools?
