What if you took a helical head and scaled it down to fit into a handplane? That’s what this model is about. It would need a motor and battery added, I believe. Curious that I could not use native tools (trim tool) to make the threaded holes from the tiny Allen Head Screw into the “Head.” Every time I tried, the “Head” would disappear. One time I even scaled up 1000x (Dave Method). I guess I should try scaling up 10,000x.
My wife found a plan in PoP. Wood. but wanted some changes. The original plan had two feeder levels instead of only one. It recommended using Red Cedar. The hard parts were making sure that the Hinge Leaf lied flat and in aligning all the parts that rotate.
My favorite tasting fresh water fish is the Crappie. This may become an inlay some day. Sizing the texture based on the image shown was difficult. Once I edited the texture width, a gray line showed up. I had to edit the width to size the spots. I’m not to good with the texture tool.
I think I did a little better this time. I didn’t bother making the fins so thin, I sized everything a little better, making it easier to apply the texture, and I didn’t bother applying texture to the thickness, since it’s going to be inlaid into a panel someday. These little fish can be tasty too. Edit: These are called Pumpkin Seeds in these parts.2d Edit: I learned that when you flip a face that has a texture, the texture goes with it. Good thing since at first I was applying the texture with the fish’s head point 180 degrees off on the back side.
The record Walleye for Arkansas was caught on 03/12/82 at Greers Ferry Lake at 22 pounds, 11 ounces. This was a world record at the time. This is not as heavily fished here as it is in the upper Mid-West U.S. and Canada. I have never caught one, but I hear that they are very tasty.
This chisel aid is set at 3/8” for guiding the chisel work or it could also guide a drill bit. I tried out AI Assistant. I don’t know what language it translated my notes and dims. Somehow my notes and dims. got corrected. I was having problems saving so I made the screenshots before I signed out. The skp I attached doesn’t have tags or scenes because of that.
I saw something like this in a catalogue for $24.10. It is used to keep a bench vise from racking when a work piece is clamped on the other side of the vise chop.
This became more complicated than I thought it would be. I made tag folders to organize the scenes. This is a fixture for using a router to flatten a slab.
After seeing a Woodsmith Magazine video with Phil Huber, I decided to model this board. I have been just using my dog holes and bench top for small panel glue-ups which works. This is better, though, because of the melamine cover of the base which resists glue. This is not an exact copy, but close based upon my feeble memory.
Nice. I made a small-panel clamp years ago that I like very much. Can be made any size but the base board on mine is 24 in. square. Your point about having the melamine laminate is good. I usually put down a sheet of waxed paper or a strip of blue painter’s tape along the seam lines.
This holding fixture can be made out of melamine plywood or fiber board (for glue-ups) or out of unfinished plywood (for workpiece holding). For bigger panels fixtures can be place side by side or upside down and turned 90 degrees for cross clamping.
I modelled this using a Vee Chisel but a router could be fastened on top of Side instead. The hard part is making a usable thread cutter to make the Nuts.
Here are a couple of dust shield profiles I was thinking about using for a chest. I am 99% sure that it will be the simple profile since they’re for a tool chest.
The last model was about the profiles of the dust shields, and this one is about the joinery for the dust shields. The joinery is called mitered, through dovetails.
