Model Suddenly Disappeared
I have been a user for 1.5 years. Designing a post-frame workshop 30x40x16 and, when almost finished, the entire model disappeared. Everything in the model is in groups and tags. After I turned off all the tags, now even though I have turned on many of them, I can no longer see the parts of the model represented by them. I also looked at several posts like this and, after trying the various suggestions, nothing has helped.
Share the .skp file so we can try to help you.
I do not see an upload icon here…
If the file is 16 Mb or smaller you could also just drag and drop the file into a reply. If it’s larger, upload it to DropBox or Google Drive and share the link.
BrokenSlabPostTrussGirtPurlDoorWindRoofDripCoverSteelOsbWrapWindDoorWainsUppersCorners.skp (9.0 MB)
Here you go. There were a lot of tags turned off in the model and the camera was balled up but I fixed that. I made a scene that you should be able to return to if you get the camera screwed up again.
BrokenSlabPostTrussGirtPurlDoorWindRoofDripCoverSteelOsbWrapWindDoorWainsUppersCorners FIXED VIEW.skp (9.2 MB)
Thank you. What did I have wrong with the camera, so that I will not do it again?
It was placed at a great distance from the model. Not sure how you got it that way but Zoom Extents, which would normally manage to fix it didn’t. I used a different tool to fix it.
Going forward make at least one scene showing the model early on so you can always return to it if you need to.
Oh, and you’re welcome.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
