Hi, can anyone help me, I am modelling a project, and I imported a 3DWH model (a fridge to be exact), then it suddenly zoomed out and stuck a bit, then I saved it for well saving file, then reopened it and its now stuck on axis and cant see my model. Zoom extents did not fix it nor my saved scenes.
Fixed ! XD, weird ghost model
Some components you downloaded from the 3DWH have reversed faces, there are also a bunch of unused stuff I guess also added from the models you downloaded, it’s not a good practice to download 3D models into your main model, there are a lot of corrupted or unnecessary detailed components in the 3DWH, in some cases entire files have been corrupted without possibility to recover them. The size of your project is relatively small but it´s over 135MB, purging it will reduce the size but you should also get rid of some objects that are huge to be an asset, they alone weight more than the entire project, you had also 4K materials that aren’t even the main object of the project, it was a white glossy material.
Doing that reduced the size from 136 MB to 41 Mb, that without getting rid of the heavy objects you still have.
Those components are very heavy according to CG Impact report Plugin.
Here are the purged files without the heavy assets 32MB
and just the heavy assets 25MB
