Hi,
I have a lot of problem in SU2017.
The model Info window doesn’t appear, anywhere.
The file stops working when I try to change color of any layer.
There are problem opening file: I have to run sketchup many times to have any file open.
I try uninstalling and re-installing. the first week everything goes well. Right now there are still the same problems.
Box
2
Do you have more than one monitor?
Can you open, Window/Preferences and hit Reset Workspace?
I just run the “Sketchup 2017 Checkup”.
The problem is on my graphics card memory.
Well, running Sketchup on 1 monitor, everything works.
I should probably use Sketchup 2016.
Thank you @Box
Carlo, this NVS 3100M is a multi-display business card.
It is not meant for graphics nor gaming. It only has 16 cuda cores.
