I have an architectural model, near to completion, that is now disappearing when I rotate view around it. After that happens I cannot then bring the model back into view. The files becomes unusable. Our process has been to use a copy of the previous day’s file in order to have daily backups for this reason.
You’ve got some entities located at a huge distance from the model. Delete them and the issue will be resolved. I selected the house models as below. Then inverted the selection and pressed delete. No more blanking.
BTW, it wouldn’t hurt to fix incorrect tag usage, purge unused, and reduce the largest of the textures in the file.
45 Cascadilla 9-24-24 A purged.skp (11.5 MB)
Thank you very much, perfect
