Is there possibility to store in Model Attribute hash?
array_h = Hash.new
Sketchup.active_model.set_attribute(‘dynamic_attributes’, ‘TYP’,array_h)
array_h = Hash.new
(1) Are you sure you want to put attributes into a 'dynamic_attributes'
dictionary ?
You need a good reason to do so, as it is a shared dictionary.
(2) There currently is NO model level 'dynamic_attributes'
dictionary.
(3) If you wish to store your extension specific attributes, then create your own dictionary.
SpecificAuthor_SomeSpecificPluginName_SpecificDictionaryName
So say you had a “Widget” plugin, and you needed to save model specific settings:
dictname = "Mamjankowski_CrazyWidget_ModelSettings"
If your “CrazyWidget” extension has only 1 (one) total dictionary, then you would not need to “difference” the name, and you could shorten it to:
dictname = "Mamjankowski_CrazyWidget"
I strongly advise that the first two parts of any attribute dictionary name be the same as your toplevel module name + your extension sub-module name.
That way people can tell what extension a dictionary belongs to.
You need to avoid dictionary name collisions between your own extensions, as well as everyone else’s extensions.
Arrays are not a Hash.
A Sketchup::AttributeDictionary
is not a hash, nor a subclass of Ruby’s Hash
But they look very similar, and both have the Enumerable
mixin module included.
my_hash.each {|key,value|
dict[key.to_s]= value rescue dict[key.to_s]= value.to_s
Hashes can have any object reference as a key, but attribute dictionary might not.
Some value (object types) can be directly saved to and read from attribute dictionaries, but not hashes.
Test fully.
