Memory leak in SUEntititesFill () in case of degenerate triangle
Hi,
An other memory leak problem is found while testing the SketchUp 2016 SDK in ARCHICAD on Mac OS X. It seems SDK does not free all objects when we give a degenerate triangle to it (degenerate means collinear points).
A minimal code sample, with which this problem can be reproduced:
    // Create an empty model
    SUModelRef skpModel = SU_INVALID;
    SUModelCreate (&skpModel);
    SUEntitiesRef modelEntities = SU_INVALID;
    SUModelGetEntities (skpModel, &modelEntities);
    // Use a geometry input object
    SUGeometryInputRef geometry = SU_INVALID;
    SUGeometryInputCreate (&geometry);
    // Add vertices (collinear points)
        std::vector<SUPoint3D> vertices (3);
        vertices[0].x = -9.06436;
        vertices[0].y = -2.9534;
        vertices[0].z = 2.35;
        vertices[1].x = -9.86436;
        vertices[1].y = -2.9534;
        vertices[1].z = 2.35;
        vertices[2].x = -9.88936;
        vertices[2].y = -2.9534;
        vertices[2].z = 2.35;
        SUGeometryInputSetVertices (geometry, 3, vertices.data ());
    // Add face with one outer loop
    SULoopInputRef loop = SU_INVALID;
    SULoopInputCreate (&loop);
    for (size_t vertIdx = 0; vertIdx < 3; ++vertIdx) {
        SULoopInputAddVertexIndex (loop, vertIdx);
    SUGeometryInputAddFace (geometry, &loop, nullptr);
    // Fill entities with geometry
    SUEntitiesFill (modelEntities, geometry, true);
    SUGeometryInputRelease (&geometry);
    SUModelSaveToFileWithVersion (skpModel, "filePath.skp", SUModelVersion_SU2016);
    SUModelRelease (&skpModel);
Our memory detection shows more places of leaks in this case:
1)
SUEntitiesFill
COctree::StorePoint(atlast::geometry::CPoint3d const&)
COctree::FindVertexInTolerance(COctVertex*, bool)
operator new(unsigned long)
SUEntitiesFill
SUEntitiesFill
GeometryHelper::CreateEdgesAndCurves(CVertex**, sketchup::slapi::LoopInput const&, scoped_array<CEdge*>, scoped_arrayatlast::geometry::CPoint3d, unsigned long*)
SUEntitiesFill
CEdge::CEdge(CVertex*, CVertex*, bool)
CVertex::AddEdge(CEdge*, bool)
CShortArray<CEdge*>::SetMaxSize(unsigned short)
We use the workaround to check the triangles before pass to the SDK, but I think it would be better if the SDK could handle this kind of triangles itself.
Thanks,
Tamás Zolnai
Thank you very much for your detailed bug reports. I’ve logged this internally as SU-33879.
Really sorry for the inconvenience.
