Had to take a break from the plugin code for a few days and migrate my server to a new better arrangement in Seattle. One of those necessary evils of running a primarily online business.
Happy to say that I think I’ve made the transition successfully (after a few stressful days and all nighters). Hopefully back in the saddle today and looking at the window/door modules and generic walls, this one should be interesting.
I think Medeek Doors & Windows should be a separate extension from Medeek Walls. Perhaps if Medeek Walls would be able to recognize these openings made (or moved, even by 3rd party extensions or manual methods) then that would be good.
Workflow wise it doesn’t make sense programming doors & windows in from the start (or early on), these things often changes (and may change often).
Is there ever a situation where you need more than three king studs or three trimmer studs? I don’t think I’ve ever seen more than this framed up next to a door or window but I’m sure there are special circumstances.
New codes are getting more elaborate about king studs, and, as I understand it, the total number of studs tends to be about the number of studs taken out by an opening. If so, that would mean a 16’ bi-parting slder would end up with 6 king studs at each side. Yup, that’s a lot of wood. My understanding is it’s for resistance of lateral loads perpendicular to the wall surface.
The elimination of the negative offset should make the wall move tool a lot more intuitive to use. Please feel free to give me further feedback in this regard.
Rather than a tee intersection you have two walls forming a corner and then a third wall tying in at the corner. Currently I really don’t have a good solution for this scenario since one would probably need to offset the sheathing or gypsum back where the tertiary wall ties in.
I will need to give this some further thought. Any ideas or suggestions are always welcome.
I’ve identified a possible bug or issue where the top plate cutout algorithm tries to cut out a zero thickness slice from the adjacent top plate in this particular scenario, I will release a fix for that shortly.
This latest update is a necessary and major rewrite of the window and door modules. As such, this update will break compatibility with previous versions of the Wall plugin. It is highly suggested not to upgrade to this latest version for existing projects that were created with previous versions of the plugin.
Fixed a critical bug with the recently updated window and door edit menus.
*** IMPORTANT ***
This is a critical bug fix to Version 1.2.5. When the source code was compiled for this version the updated HTML files (window and door edit menus) were somehow not updated as they should have been. I strongly suggest that you update from version 1.2.5 to version 1.2.5b, otherwise you may not be able to edit your windows and doors.
I’ve had a number of requests recently for an air gap for the interior of the wall (air gap between the framing and gypsum).
It seems this air gap is typically for furring strips or possibly a foam insulation layer.
I don’t think it will be much of an effort to add this additional feature but I just want to gather further feedback and see if there is enough interest in taking the time to include an extra interior air gap parameter.
Please feel free to comment or send me comments directly to nathan@medeek.com.
3.) Then select the new position of the wall start/end. (A wire frame is provided along with a dimension). The user can either select the position or key in the amount to stretch or shrink.
This feature is in many ways related to the move tool since stretching a wall will also move any attached walls at the affect corner. Additionally when the start of the wall is moved the location of any features within the wall must be relocated so that they maintain their position, just a few things to think about.
I’ve also setup the tool so that when you select the wall start or end you don’t have to actually select within the circles shown. The tool will calculate how far your mouse click is away from each end and select the end which is closest to the mouse click.
