Medeek Wall
Version 4.2.7 - 01.26.2026
  • Added a kick plate option for all swing doors (rectangular and arched).
Yet another update following up on a customer request. Probably not the highest priority on my list but a welcome addition for those that need this feature.
The kick plate(s) can be positioned on the exterior, interior or both sides of the door. The height and thickness is configurable. For now the margin at the edge is hard coded in at 0.75 inches (width is auto calculated based on door size). The material (ie. brass, nickel etc…) is configurable the same way the door hardware is.
Tutorial 81 - Door Kick Plates (4:29 min.)
Version 4.2.8 - 01.27.2026
  • Added the following steel column types to the column module: Round (HSS), Pipe (NPS).
Update per customer request.
You can now add round steel in-wall columns into your Medeek walls. These aren’t actually lally columns since that specific product is typically installed with an adjustable screw assembly. However for most design purposes I think showing the round column like the image above will suffice.
One of my favorite lines from Mr. Blandings Builds His Dream House:
“…on the second floor, the lintels between the Lallys, you want they should be rabbeted?”
Seriously, seeing a pipe column bear either end on a plate looks suspect to me - worrying about Fc-perp not being up to the load a pipe column can take.
You are correct, one would never set up a pipe in a wall like this, it would just embed itself into the wood plate(s). I was demonstrating the in-wall column with the default settings.
If one adjusts the height parameter and the vertical offset parameter you then end up with a more realistic configuration (notice the king studs also on each side of the column).
With the opening and closing of bypass doors my youngest son noted that it would be nice if one could control which side actually slid open. After some thought and recalling a certain state logic lesson (control of an elevator) in my mechatronics class years ago (1999) I then came up with this:
bypass_door2
You basically just keep clicking on the door until it arrives at the configuration you want. It will now alternate which side it opens.
Version 4.2.9 - 01.30.2026
  • Added a base plate (top and bottom) option to the post module.
  • Fixed a bug in the post module related to hardware caps and bases.
  • Updated the bypass door opening algorithm so one can open both sides of the door.
Version 4.3.0 - 02.01.2026
  • Added a base plate (top and bottom) option to the in-wall column module.
  • Added “Opening Outline” options to the General tab of the Global Settings for windows, door and garage doors.
The option to set the opening outlines as regular edges or dashed (construction lines) was requested by a user. This option only changes the outline created at the top of the wall, it does not change or remove the door swing symbol or the garage door extent outline (dashed construction line).
I’m trying to not add more parameters and options but users always contact me with something new they need. Everyone has their own workflow or the way they want things to appear in Layout. Flexibility and a smorgasbord of options is critical but at the same time it does balloon the number of parameters and increases complexity which tends to scare away some potential users.
I always tell new users to not be frightened of all the options, if you don’t know what it does then just leave it as default, that is generally your safe bet.
Version 4.3.1 - 02.02.2026
  • Added a six panel option for pocket doors.
  • Added a six panel option for bifold 2 and bifold 4 doors.
  • Added a six panel option for bypass doors.
Version 4.3.2 - 02.05.2026
  • Added flat panel options for pocket doors.
  • Added flat panel options for bifold 2 and bifold 4 doors.
  • Added flat panel options for bypass doors.
I think that finally completes all of the door panel options for all the other non standard door types (rectangular doors) within the Wall plugin.
Most of this updating is a bit tedious since there really is no new code to write, just shuffling around existing code and recycling certain blocks here and there. I think after this update I will jump over to the Floor plugin for a bit and take care of some pressing matters before diving back into the Engineering plugin and then the Plumbing plugin.
Keep sending in those feature requests, they are very much appreciated and valued. Not all feature requests make sense so I do hand pick the ideas that I want to implement, but I do my best to seriously consider each and every request.
Send me the model (nathan@medeek.com).
Also lets try no to fill up this thread with too many support requests. If you have specific issues feel free to email me at the email above.
Not specifically related to the Wall plugin but the Order History in the Account Manager on the Medeek website will now show all plugin (extension) orders. Previously the Order History button only showed planset orders. Something I should have fixed on the website years ago, but too busy coding the plugins.
Nathaniel, have you considered adding a deck railing module somewhere that would create railings with similar options to exterior decks? That is one of the few items that I cannot do with Medeek extensions.
Version 4.3.3 - 02.08.2026
  • Added the following Simpson Strong-Tie anchor bolts to the wall, column and shearwall modules: SABR58-24, SABR34-26, SABR78-28, SABR1-30, SABR114-32.
These new anchor bolts are included in the new Wood Construction Connectors Catalog (C-C-2026) for 2026.
https://www.strongtie.com/bolts_anchorbolts/sabr_bolt/p/sabr
These low poly versions of the anchor bolts are based on the models provided on Simpsons website.
Yes, I need to add in a railing tool, both for stair landings and decks. I will probably add this tool to the Floor plugin.
Version 4.3.3b - 02.10.2026
  • Fixed a bug with pocket and sliding glass doors as related to the sidelite and transom options.
With metric (in Europe) millimeter wall settings, when trying to calculate the cost of wood, it does not calculate the price for Studs, TOP PLT, BTM PTL, Cripple studs. Is this normal or is it not working yet?
It should also work for metric units, if you are getting specific error, please email me more info at nathan@medeek.com
Version 4.3.4 - 02.13.2026
  • Fixed a bug with bypass, bifold, pocket and sliding glass doors as related to the sidelite and transom options.
  • Fixed a bug with the kick plate option for doors.
The kick plate bug is not actually a bug with the new feature it just allows for editing of existing doors that did not have the kick plate parameters stored in their attribute libraries. A backward compatibility fix.
The bug with sidelites and transoms is a more complete fix that gracefully disables these features for specific door types. Note, that it does not toggle off these options if they are enabled for a specific door, the user still needs to turn off sidelites and or transoms within the edit menu, for the nag messaging to go away.
Just some small fires that needed putting out.
Version 4.3.5 - 02.15.2026
  • Added the ability to create custom “Beveled T&G” wall cladding materials within the Material Library.
  • Enabled “3D” Beveled T&G wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
This 3D material by customer request.
The three numeric parameters in order are: board spacing, bevel height and bevel depth
An example of this 3D material might be: beveltg_6.0_0.25_0.25
