Testing the reference underlays for the Upper Floor Plan (level 1 wall framing and level 2 floor framing):
Editing a complex roof is relatively straightforward.
Multi-story construction. Don’t judge this design to harshly it is not meant to be anything other than a test vehicle to see if I can get all the levels lining up correctly.
The vertical dimensions need some work:
Basic all-hip complex roofs are enabled but I now need to work on custom roof planes (ie. Gable, Half Hip, Dutch Gable) and along with that, the always more challenging, vertically offset fascia lines. My head hurts just thinking about it.
Complex roofs is still a work in progress, no surprise there. The interface will mirror the Truss plugin since we already know how that works. When a roof is selected the “custom” roof planes (edges) will display in red rather than blue. A selected edge will switch to a solid color and the right hand menu will display the settings for that roof plane.
The same settings that are available in the Truss plugin will appear for the selected “roof plane type”.
Now we throw the kitchen sink at it. First we start with various pitches applied to different roof planes and see if we can break it.
Then we try some more challenging roofs with re-entrant corners.
None of these roofs are realistic but they do prove that the solver is behaving as expected and we are able to accommodate any roof plane/pitch combination.
Looks like we will also need to add in hip walls for these “half hip” type roofs:
I’ve also added in the Dutch Gable option for roof planes as well:
This almost completes my work on complex roof in the house builder. Of course some additional work remains in connecting the House Builder to the Truss plugin’s API. I will also need to enable the API with some new methods for complex roofs, but that work is relatively straightforward.
Tomorrow I will look at the Roof Plan tab and probably add in a few more roof specific annotation options. Then from there we double check that the Print and DXF functions are wired up correctly.
And then finally we move on to Foundations.
However, this additional work on complex roofs has exposed the fact that I need to enable additional wall types in this app.
I haven’t exposed all of the options in the House Builder that exist in the plugins, I am trying to keep this as light weight as possible, yet giving the user enough options to make this a viable design tool.
To that end, I’ve enabled exterior trim for all openings:
Since we have trim for doors, garage doors and windows now, we will need to enable the other exterior trim options for the walls (ie. corner trim, band boards, frieze boards and skirt boards (with or without a drip cap). Why do these rabbit holes always get so deep?
Labels are working and I’m actually calculating the Area and Volume mathematically. Normally I just rely on the area and volume methods that are built into the SketchUp API, however in this case there is no SketchUp face or “solid” yet, so it is a bit more tricky, and it requires a whole new algorithm.
Next I need to work on interior footings.
I could get carried away trying to represent all those beveled edges, but I think a more stripped down simple approach is probably better (and easier to code on my end).
