I’ve also added in the UK outlets and switches:
I think it might be useful to have a fixture tool for adding in baths, showers, toilets etc… Even though this feature does not yet exist in the plugins.
New items for medeek plumbing?
When I say fixtures I basically mean anything that normally gets put into a floor plan that is not part of the structure, but is either furniture or semi-permanent.
- bath
- shower
- lavatory
- cabinets
- water closet (toilet)
- sinks
- appliances (washer & dryer, range, dishwasher, Refrigerator)
- wood stove, fireplace
- water heater
- furnace / AC unit
Other additional items that may be useful but are not normally part of a typical plan are:
- beds
- couches
- table and chairs
- automobiles (ie. standard truck and car)
- desk
- drawers or wardrobe
- misc. furniture
I think something like this would be most welcome.
What would be great is if this had low / medium / high poly versions one can readily swap out by a button override. Of course, it would be rally neat if the plugin monitored the camera distance from the objects and automatically swapped between high / medium / low poly options of the same item.
Perhaps have it set up where one can add your own items, to supplement a curated selection already shipping with the extension, as well without too much fuss. Something like drag and drop your high poly item into a dialogue window, it automatically creates high / medium / low poly versions of the item. Perhaps even 2D snapshot on all 3 axis that one can use in technical documentation and do not really require the eye candy version.
I suppose one can dream…
The House Builder is now building all wall-hosted electrical fixtures:
Version 1.3.1 - 10.27.2026
- Enabled electrical plans within the House Builder.
- Created a Medeek API for the Electrical extension and wired it with the House Builder.
Tutorial 9 - Electrical Plans (14.41 min.)
Unfortunately I forgot to show the electrical legend in this tutorial.
Note that in order for the House Builder to work correctly you will need to upgrade your Wall, Truss, Foundation and Floor extensions to the latest versions (released on 10.19.2026). You will also need to upgrade your Electrical extension to the latest version (released on 10.27.2026).
Here is a quick demo of the electrical legend in action:
I got the block editor and the DXF import utility mostly put together today and then proceeded to import some of my old AutoCad architectural blocks into the House Builder. I quickly realized that many of my bathroom blocks involved actual ellipses (for sinks) and spline curves (for toilets) so now I am adding in ellipses, elliptical arcs and splines.
Version 1.3.2 - 11.04.2026
- Enabled blocks within the House Builder.
- Created a Block Editor and Block Manager for House Builder blocks.
- Added the following drafting primitives to the House Builder toolbar: Ellipses, Elliptical Arcs, Spline, and Blocks.
- Added the following modify tools to the House Builder toolbar: Move w/ Base Point, Rotate, and Mirror.
- Addressed a number UI and performance bugs in both the House Builder and Block Editor.
I have had some requests by users for some sort of AI integration within the plugins. That was actually the reason for my fairly recent addition of the Medeek API a few months ago. However the API alone is only an adapter so that AI can connect (MCP server) to the extensions. I have not yet created an actual AI integrated tool or plugin. I may give this some further consideration however it will be experimental at first.
I’m not even sure that an AI can realistically understand a floor plan very well and what it means to do proper “space planning”. If it can then I will be genuinely surprised but it remains to be seen. If it can’t then all of our jobs are safe for while longer.
