I actually have given this more than a passing thought and there is no technical reason why we should not be able to import Medeek assemblies back into the House Builder. I will eventually explore this further.
I currently have to finish adding in a number of foundation assembly types and then the custom wall types (gable, hip and shed). After that I need to wire up a few more API calls/methods that the House Builder requires. Finally I will look at the reverse function or importing assemblies into the House Builder.
Slabs are now able to print and export to DXF. As you can see they look very similar to Slab-on-Grade assemblies and have the same interior footing and slab depression capabilities.
I’m now spending a day or two integrating the eight different foundation assemblies into the elevation views. Here is a couple examples of column footings:
I am now trying to wrap up stemwall foundations and the addition of windows, doors and blockouts, all within the elevation views. After further testing I’m noticing that all of this added complexity does potentially slow down the app/tool when enough windows, doors and dimensions are added. I will need to spend a few more days tightening up my “redraw” algorithms so that performance is maximized. The last thing we want is a sluggish interface.
