Added a duplicate foundation assembly check to the regen module for the following foundation types: Stemwall, SOG, Slab, Stemwall Step, Grade Beam, Strip Footing, Footing.
The instructions for usage are the same as the recent update to the Wall plugin, see Wall Plugin Tutorial #51:
Trying to figure out how to sketch a FPSF with a turndown using the plugin, ( much like what’s shown here ) but I cant seem to figure out how to do it . . . . looke through the youtube videos but still wondering what the correct approach is
Let’s try to restrict this thread to development questions and comments. For tech support questions feel free to message me directly or email me at nathan@medeek.com.
The foundation plugin is great. I was able to create this stairwell from the garage to the basement with no issues fast. It is an 8" stem wall 9’ deep.
I ran into an issue when I tried to recreate the same design using a 10.25 wide Superior Precast wall. It has no footing, and because it’s purchased, I turned off everything except anchor bolts but crashes every time. For some reason it draws a group over at the 0,0 origin as well.
This was a feature add that desperately needed to happen. This will now allow one to move anchor bolts around so that they do not interfere with doors and garage doors.
The density of the concrete, CMU and steel can all be customized in the global settings as shown in the image above. I will probably enable this feature for other foundation assemblies if it is requested.
