Measuring tool not working
when i use the measuring tool it works for a little while then gets buggy and won’t snap to a line or point for taking a measurement. the only way to fix it is to close the drawing and re open it again. very distracting and frustrating that i have to constantly do this.
help
-ryah
When you say measuring tool, do you mean the tape measure or do you mean the tool that leaves text measurement? If you describe or give a screen shot of what two points you are trying to measure, I believe some the of sages can help you out.
Normally, the dimension tool won’t anchor unless you start at an endpoint. In the screenshot I put guidepoint where there was no endpoint. The dimension tool will anchor on a guidepoint and even where two guidelines intersect. After I made the dimension, I erased all guides, leaving just the text dimension.
This may help to explain: Tape measure tool
