Measurements in negative?
Hi! All of a sudden, measurements above the plane are all negative now. Only time the measurements are positive is when I push below the plane? Is there some reverse setting that I am unaware of?
Sounds like the Axis has been inverted. You can find the axis tool in the tool bar on the left with the tape measure tool flyout… your axis should look like this:
Screenshot%20(28)
Not like this:
Did you insert a model from the warehouse?
Thanks for the reply. It seems I must’ve clicked CTRL, which appears to change the measurement from negative to positive. Thanks again.
Ah…yes toggling ctrl while pushing/pulling can invoke a couple of differet responses.
