trying to find out if i can turn the fractions in su to decimal, ex: 1/16 to 0.0625 while I’m creating a shape or line. Is this possible?
Sure. You can change units and unit format, e.g., fractional, decimal, as often as you wish. The new unit of measure will be used by default in all subsequent measurements unless you change it again. See Window > Model Info > Units, and study the values in the dropdown menus,
-Gully
It worked thank you Gully
And even if the units are set to fractional you can still type 0.0625 and it will know what you mean.
