Hi,
I want to know if it is possible to autosave with maxwell for sketchup? So the image saves it self when rendering is done.
Thank you!
I will. But this forum is more active, so if anyone knows?
I don’t have Maxwell installed, but the manual mentions a command line feature in the scene manager that is used to start the Fire viewer (I believe that this is only available in the Render Suite [RS] version):
The manual describes this field as:
Command Line
Anything entered here will be added to the command-line used to start Maxwell Render. By
default, it contains the -d flag, which causes Maxwell Render to start in GUI mode, and the -
p:low flag, which causes it to run in low-priority mode. There are many other command-line
flags available, and you can get the current list by opening a command prompt, navigating to the
Maxwell directory, and typing maxwell /?.
Since I don’t have it installed, I can’t see if there is an auto-save option you can add. If not, there doesn’t appear to be a way to do this.
Thank you! Will try it out!
