Hi Linng. Indeed a strange story. I opened your file again on the M2 macbook, and the artifacts were there, with setting on nicer. On faster they disappeared. Checked it again on the Studio Max, and the same happened. So now I tested it with my own files, and on nicer the transparents acted all the same way, with the artefacts on nicer setting. Now I was sure I always had nicer on, but I see now that the template I made when I started using sketchup 2022 has the setting faster. And on that template I build everything. Never noticed anything strange. However, I do not see where the setting has any effect on the results of my renders, it does not influence the behaviour of Podium renderer. Sorry to have confused you, I should have checked double first.
Hi everybody.
I have exactly the same issue as Linng has.
Use to work on an old 2012 Mac Pro with witch I never had this problem.
It appears since I work on Mac Studio M2, (witch sketch 21 running on Rosetta 2)
And indeed Nicer transparency is useful when two or more transparency plans are superposing.
@linng : did you find a solution since this conversation ?
